ok little history we sucked a ski rope into the impeller theengine over heated it was shut down and loaded the boat
once home and all the rope removed i pulled the pump to check the drive shaft and impeller wear ringand what nots
had to rebuild the drive line.... all is back together new parts got all set up for test run....will not crank engine turns over fine and it even hit twice but nothing after that. ive pulled all the fuses and checked the fuel lines?
any ideas would be helpful im circuling the drain here!!!
