I have a 1999 Sportster 1800. I've searched the forum, but haven't been able to narrow down the issue.
I rebuilt the carbs on both engines over the winter. I have also replaced the fuel filters and oil filters as part of my normal spring maintenance. I took the boat to the lake today for a test run. Starboard engine is running great. Port engine is giving me a little bit of trouble.
It will crank normally with the choke pulled, but will not idle or run well at less than about 4000 rpm. If I crank it and give it 3/4 throttle (along with the other engine idling and pushed to 3/4 throttle), it runs well. Bring both engines down to about 3500 rom, and the port engine will just fall off and die.
I pulled the plugs. The starboard engine's plugs look pretty good. A little shiny and brown. The port plugs look grey and dry. I checked the fuel lines for any loose connections, and played a little with the low speed screw with no real impact.
Any advice I could get with troubleshooting this would be greatly appreciated.
