Sporster 2001
Lms
Sporster 2001 , when i plug the key i have noting , no beep beep , no power , all the fuse is good , i try a oder key and its the same , and when i plug the scan tool i have no communication whit the mpem !
Exuse my english its not perfect;-)
Tanks
I am sure you will find you have a junk battery, bad cable, or poor connection. For a simple test, jump between the two large terminals of the starter solenoid. If it cranks, then the battery, cables, connections, and starter are good. If it does not cranks, one of those is the issue..
