Hey guys, I'm going to be splitting my cases to clean them out, when I took the top end off, some grime fell into the crank and I am going to pop the bottom case half off to clean it all out an make sure everything is OK in there. I'm doing this to a 787 and a 951.
My question is do I need to remove the pto, and flyheel, or will it split and lift out with them still attached? I dont need to remove them and wont if it will come out with them intact. In some motors, I know there's bolts and stuff under the flywheel or pto. I dont think there is in these, just wanted to check with someone who has done it a few times.
