spi idle problems
kobymerryn
hi there guys!
i have a 1996 seadoo spi, had it for 2 years, an had loads of fun on it, never had a problem with it, until recently i replaced the engine mounts, got the engine re-alined, and had to change the fuel tap.
the last 2 times i.ve taken the ski out, for some reason, from idle to full throttle, the ski dies, an boggs down, an if i let go of the throttle, it will go back to idle, but sometimes, it'll work fine?
it starting to bogg down a little when cornering an at full throttle, an has gotten worst the more i use the ski.
since the last time i taken it out, it wont idle out of the water.
the only way i can get it started is if i manually ajust the chocke in an out while starting the ski. then once it is idleing, the engine will idle at normal rpm, then it'll start to rise in rpm, then drop in rpm untill it cuts out?
hopefully you guys can shed abit of light on what i can do to fix this!!!
many thanks!! ryan
