Speedster215 supercharged 2008 Accelaration
G factor
Hy!
Im new in this forum, ihope you can help me.
Since my chain brokes an i needed a new cylinder head Made by Dealer.
I have the problem when i but the gas on full the speed is
going up slow or better to say on full gas the engine just turns on t0 max rpm and cut off and the accelariton is not like before.
If i accelaret .
slow but gas slowly to full its working perfect.more persons harder to accelarted with out cutt off...
I put as well new engine oil in syntetic new one for all engines.
Please help...im sorry for my bad englisch its not my mother language
From reading through your post it sounds more like a pump problem than an engine one. If the engine is going to max rpm when you try to accelerate, but you don't pick up speed, it means the pump is cavitating. There are a couple of things that could cause this, from trash being stuck in the pump, to a worn out wear ring, or it is sucking air past the drive shaft seal.
Aaron:cheers:
Language barrier....
Hy!
If i accelaret .
It is pretty hard to understand your exact problem due to the language barrier. Please, if it's easier for you to give us a very descriptive aspect of what your problem is, please use your native tongue. We have translaters to be able to convert to our lanuage to better understand what we can do to help you solve your problem.
Um nicht zu verstoßen, aber weiß ich, dass es auch gesprochene Minderheitssprachen gibt, wenn Ihre Muttersprache Croate oder Serbisch ist, helfen Sie mir bitte hinaus, und lassen Sie mich wissen. Ich werde alles tun, dass ich kann, um Ihnen zu helfen, aber Sie müssen im Stande sein, sich zu äußern, wo es leicht verstanden wird.
Es ist ziemlich hart, Ihr genaues Problem wegen der Sprachbarriere zu verstehen. Bitte, wenn das für Sie leichter ist, uns einen sehr beschreibenden Aspekt dessen zu geben, was Ihr Problem ist, verwenden Sie bitte Ihre heimische Zunge. Wir haben Übersetzer, um im Stande zu sein, uns zu unserem lanuage umzuwandeln, um besser zu verstehen, was wir tun können, um Ihnen zu helfen, Ihr Problem zu beheben.
