Hi guys, adding to my ongoing issues with this boat this season, my starboard engine wouldnt go over 5000 rpm in the water. When i got it home I checked the impeller and found a bamboo sized piece of weed stuck in the blades. So i'm hoping thats why that engine wouldn't go over 5000 rpm. Since i had to take the nozzle and everything off to get the stick out i decided to check the pump oil. It seemed contaminated so i took off the cone and it was mostly full of water. When i checked it before the season it was full of oil and no contamination. What could cause the housing to now be full of water?
I'll attach a picture of the impeller, the outlet side looks good. the inlet seems a little beat up. The clearance between the wear ring is within spec. what do you guys think?
Thanks,
Justin
Thanks,
Justin
