Hello
Hi
I just ordered and received two derlin wear rings.
I had new Solas SD-SC-A & B impellers. After I spent some serious time changing the wear rings I installed the impellers. They are VERY TIGHT! I could only gently push them straight down, I couldn't turn them with the wrench on the impeller tool. I had the shaft in a vice and turned the pump clock wise and that sucked the impellers down into the wear ring. I can't turn them at all however now. Is this normal? Is something wrong? I don't want to go through this all again.......thank you!
Hi
