Speedster Taking On Water
Jnz
What are some of the locations I should check if I'm taking on water with the engines not running on a 98 Speedster with twin 787s. Taking it to the dock alone for the first time I'd say within 5 minutes I had a inch or two in the bilge already.
Exhaust outlets, weed less grate cables, carbon seal, white bilge line and the obvious..........drain plug
If running, any hose, water control valve
Didn't bother with it last year as I didn't stop and sit anywhere, but this year I might asNJ well fix it up. The leak is coming from a large black hose on the rear starboard side tucked all the way in the corner at the bottom. Are these the exhaust leaks I read about that you can't find parts for anymore?
