Nathan Mayo
IF and only if the battery has a full charge, the port starter will sound like this .......OONCK !....OONCK_OONCK..varoom!. Reminds me of an old timey steam locomotive trying to get going. Once it cranks, it will do that repeatedly with no problem for numerous restarts. The other motor does a typical....rum, rum,rum,rum,Varoom! type of start.
IF the stinker sits for one week, THEN I get this.....OONCK...OONCK....OONCK....Oooooh!....I can't turn over anymore. Even then the other side fires right up as before. The concern is that if I take the boat to the lake for a day and then the SOB croaks for lack of a topped off charge then I will be most unhappy. Battery is only 6 months old and all connectors are clean and tight. Starter is also about a year old and has not been abused or under water.............I don't think.
What says the peanut gallery? Do I take the booger out, knowing that I can limp home on engine #2? Is it just stiff inside there from sitting for 6 months? I do crank it about every 2 weeks, so I don't think that would be the problem. It sits covered in my parking lot here in sunny Orlando, so I don't think cold exposure has had anything to do with it either.
All thoughts are appreciated, even if you are only guessing. Almost forgot.........It did sit for about 3 months without being cranked and the first time I had to tap the case briskly with a long dowell and a hammer before it would budge. That worked nicely , but now it has the OONCK....OONCK Syndrome.
Grazzi !
NM
Grazzi !
NM
