2000 Speedster is just hitting the water for the first time this year and we noticed that it is pumping fuel out the vent line during operation. Someone said to try taking the cap off and that seems to make it better, but we can't run around like that all of the time. I had a shade tree mechanic look at the fuel system and while he found a cracked t fitting which he fixed, everything else seemed normal.He said he found a check valve, blew it out, and it seemed OK. This check valve seems a little suspicious to me. I have read other posts where it says to check that the lines are hooked up properly but nothing changed over the winter as far as they are concerned. Any suggestions?
