Alinvictor
Hi,
I have a 95 speedster and last year I had to rebuild the engine after I found the engine with a hole in the top of one piston. The hole was very curios how it got there... It was about 1/4" in diameter and seemed like it was melted in the piston. Anyhow, I feeted the engine with new pistons and new ring. All seemed good, I started and took it on the water but 5 mins into the ride engine dies and locks that can't be cranked anymore. Pull to the shore on one engine, tried again the bad one and surprise.... It started in half of crank... Let it idle for 5 mins no issue... Back to cruising and engine locks again in 3 mins... I also observe this engine was running hotter then the other one but when I take the supply hose out I have a nice flow...All the test were done with the boat docked in the water so the pumps were immersed.
Any suggestion may help.
Thanks
Thanks
