R rado New Member Jan 4, 2014 #1 The crankshaft position sensor value of 309 ohm. When trying to start then the value of 150 to 200 ohm. Is it ok?
Dr Honda Well-Known Member Jan 4, 2014 #2 It's just a little low. Spec is 320 to 350 ohms. But, check the air gap. It should be 0.635 mm ~ 1.01 mm Also... to your PM... the missing fuse should have 20a, and it is for the ignition. If you put in a new fuse, check to see if it pop'ed. Last edited by a moderator: Jan 4, 2014
Dr Honda Well-Known Member Jan 5, 2014 #4 rado said: What You mean pop'ed ? Click to expand... Burnt out. If the last owner pulled it out, there may have been a problem.
