Hey all, its been forever since I've had a chance to get my 05 Speedster 200 4-tec SC out on the water... going on 3 years. Luckily I had a bunch of fuel stabilizer in it so when I pumped out the tank it actually still looked and smelt like gas, just a hint darker than normal, but didn't smell like varnish or vinegar, wasn't gunky, no chunks.
So I put in 5 fresh gallons and sea foam and let it sit and got my battery charged up... insert lanyard and the port engine gauges flash and rpm cycles, and it starts right up. The starboard engine is like I don't even have a battery in the boat... the gauges don't move, the engine doesn't even attempt to start.
What's more is I don't get any beeping from the DESS and the fuel gauge does not budge either. I tried reseating the lanyard a couple dozen times and each time the port side will gauges will cycle like normal (despite no beeps) and can start, the starboard gauges and starter have zero life.
I thought perhaps I didn't connect all the grounds, but I have 3 grounds and connected them and looked for any that might have tried to hide, no missing ground cables to be found. I only have one hot cable from the battery that goes to the disconnect switch.
I tried looking at all the fuses in the 3 boxes... driver cubby and the 2 in the engine compartment, didn't see any problems.
I almost feel like it is something with the DESS, where it is not sending a power relay signal to the Starboard side engine. The blower works fine, port side everything works fine... the only symptoms are no life from the starboard side engine or gauges, no beeping from DESS and no fuel gauge activity (fuel gauge maybe unrelated though).
Anyone been down this road or have any ideas to start troubleshooting and/or where I should be looking for power downstream using a multimeter?
