My 2004 Speedster has developed a leak around the intake grate cable (at least that's all I can guess it is) that goes through the hull. It seems to be a cylindrical fitting that it is mounted in to that has unsealed itself with the hull. If I push it in firmly, the leak goes away, but once I get moving, it unseats itself and the engine compartment fills with water.
This is my first boat, so I'm not terribly marine inclined...what should I use to secure this fitting? I was thinking some sort of RTV or silicone sealant, but I'm not sure that will hold the part in place since it's not really meant to be an adhesive. Unless there is special adhesive+sealant that I'm not aware of. Epoxy? Is there a specific type to use since it's mounted directly to the fiberglass?
Any help would be greatly appreciated.
