Cerberus
Hello All,
as subject alludes to, my 'new' (new to me!) 2004 speedster 200 turns great to starboard but to port, it is a nonchalant lazy curve
. It is so wide that in one spot in Crystal River, Fl, I almost could NOT safely turn to port
. (boat was going WAY outside both sets of channel markers (100 ft wide turn at least)). Now to starboard... that is a blast and spins on a dime (nearly) and being able to hang onto the driver's rail for extra support was extra but I'd like to go LEFT as well as right sometime soon :driving:.
I have looked at the nozzles and both sets seem to travel max left and right (they both bump against the 'stop knot' on the pump housing [venturi]). To clarify, when I steer to port, the port steering nozzle moves as far to the left as it can, as for the starboard nozzle... not as much.
Here is my first question, should I adjust the link rod 'inward' (causing both nozzles centerline to move toward each other) to allow the starboard nozzle to move further to the left when I am turning left? or, failing my logic, what would you recommend...
Thanks!
BTW, I am fully self actualized and comfortable with basic maintenance. Oh, also I usually WAAAY over analyze any situation, although after spending $$$$ to get this boat into shape, I currently have none left to fix any 'OH $H!T' moments so maybe this is the right attitude to start out with.
Thanks!
