gtoimpulse
I took my boat out today it was running fine and then while towing a tube with my 110 lb son I heard a loud noise both engines stayed running but moving the throttles wouldn't do anything. Boat eventually stalled out and I was towed back in. When I got home, I noticed the cables were very loose from the lever side but I was able to start the port engine run water through the exhaust and it sounded fine. I then started the starboard and it was extremely loud. I noticed the metal exhaust pipe had come loose where the clamp was, but the engine seemed to run ok.
How could these two problems be related? I am sure I need throttle cables as they have never been replaced, but how could the exhaust pop off? Do you guys think I sucked something through the exhaust and there was too much pressure? The last time I went out, I sucked a branch and a bag in the same side, but I was idling around and saw it at the dock. Also, I had the superchargers sent out to be rebuilt a few months ago and I pulled them off myself and it is definitely possible I didn't tighten the exhaust tight enough.
Any help is greatly appreciated.
