Speedometer seadoo GTX 4-tec
ducharry
My GTX has a topspeed of 40 Mph according the speedometer.
The GTX have a topspeed of 55 Mph according the speedometer from the RX off a buddy of mine.
It seems that the sensor is wrong.
This is my question:
Can you clean the sensor or is it broken?
Greetz,
Harry
reliability....?
The speedo's are not accurate. None of them are. If you want an accurate reading, you'll need to use a GPS. :cheers:
hi, behind the speedometer there is a small adjusting pin where you can correct your speedometer. Just did it on mine yesterday. Beste way is to do it when you are driving with constant speed. Also you should have a gps beside for the correct speed. pls consider also the water speed when you are on a river.
ingo
