Sparkplug xref
Scottsmach03
I just bought a 2002 challenger 1800 w/ 210 hp m2. I went to change the plugs and I pulled out the current plugs NGK buz8h. I've called around and nobody has the plugs in stock. I went to sparkplugs.com and cross it with a champion l6vc. I called the parts house and they have these plugs in stock. They also cross the NGK plugs with a few other brands (motorcraft sp484, denso sf24, champ 5898) My question is will this champion L6VC or even the motorcraft sp484 be a ok plug to run in this engine?
Any help will be appreciated.
I prefer to run NGK. If that is the correct spark plug and it cross references to that plug, than it should be ok. The heat range is so important in these engines.
Karl
I decided im going to take out the ones I have and clean them with some cleaner and a brush and use them for this weekend. I ordered the ngk's off of ebay for 5.75 each.
