hmmmmm, that's strange?
That's weird.....the NGK cross reference guide I used stated to use the plugs I quoted.  But, if you've found another cross reference that allows this plugs use, then it's probably o.k...plugs are based on fit, heat, and resistance....so, I'm sure there are several that will work in that application.
Like Karl says, I'm not Champions greates consumer of plugs, except for my chainsaw,.........but I see your in Egypt, so it seems your limited on what you have available.
Good luck, keep your eye on the plugs by reading them for proper operation.  Don't let them run to hot.......
