Th3Skipper
Hello,
Ok, 96 GSX, low hours, was running great until it started bogging and needed carbs rebuilt and a wear ring, impeller too.
1.) rebuilt carbs (had trouble with a ceased bolt but got it off finally)
2.) removed pump and did impeller and wear ring - no issues
All was good going back together until I tried to start it up and it just clicked like a bad starter or dead battery. It did not crank at all. I determined the battery and starter were good so I dissassembled the whole thing again. I can turn the drive shaft with the plugs out back and forth but no full turns. It changes how much I can rotate back and forth each time. I can hear something in one of the cylinders under the piston rolling around I believe (pretty sure).
What can I do?
Any help would be appreciated :ack:
What can I do?
