While my friend sat waiting on the tube, i began to accelerate in my 2003 SeaDoo Sportster LE when the engine died. Not sure why i tried to turn it over again, then realizing my worst fear, the rope had been sucked into the impeller grate. I jumped in the water to try to remove and it was too tight. We were towed to shore. I took boat out of water and took it home. I removed the grate and cut the rope from all areas of the prop shaft. Once rope was removed it did not appear to have done any damage to the impeller itself, however there is a plastic tube called "shaft protector" that seems to be somewhat torn up (what a plastic tube would look like after a rope was spinned around it). What would your suggestion be next as far as what i need to look at to make sure everything is ok?
