Chips
Hi guys, I am installing 4 8" Rockford Fosgate speakers and the Fosgate 800 watt marine amp in my 1999 Speeadster SK. I am going to buy some wire for power, ground and the remote switch line for the amp and just want to know if there are any recommendations for gauge.
Also, I cut holes and installed the two speakers where the factory front ones used to be...and it was much easier than I thought. I was worried about fiberglass going all over the place and flaking and so on but it really didn't happen. I used my Rockwell oscillating/sonic cutting saw and it worked really well. I just used a marker to draw the template and then went around the inside of the line with the half circle style blade and lightly made a groove, and then it basically tracked on its own in the groove and cut the hole...
I need to cut the holes for the rears and I have to remove some of that styrofoam. Not sure how to approach that job yet, so any suggestions are appreciated.
