RG123
I'm having an electrical issue (I think it's mostly electrical) with my 1996 GTX, just looking for some advice.
-Background: boat is a 96 GTX, stock, with fully rebuilt carbs and genuine mikuni parts, pop off set to 32 and 32, fuel selector and water separator filters are all new.
-The problem: Bogging hard down low around 2600-3000 RPM. Upper RPM seems to be unaffected. I can be patient and gradually try to nurse it through the boggy zone, gradually going deeper and deeper into the throttle, and backing off if it seems close to dying. Eventually I can nurse it up to high enough RPM to hit WOT and it will get through the bog, and then work fine staying at 40-100% throttle. If I don't shut it down, It's much easier to get through the boggy zone. This has been an issue since last year, but I unplugged the rectifier red wire, and it ran much better. Because of this, and seeing others having similar issues caused by a rectifier problem, I figured it was the rectifier, and ordered 2 Titan rectifiers from OSD. (Given that there aren't any really reliable ones available, I figured it was best to have a back up).
I didn't get to ride again until this season, so I tried the first one out. Problem was still apparent, but not quite as severe. I changed the rectifier to the other new one, expecting a better result. This time the problem was worse, and the rectifier seemed to be extremely hot to the touch.
-The testing: I tested the rectifiers by putting a voltmeter on the battery leads with the ski running, per the shop manual. I had checked all the connections and fuses in the front and rear electrical boxes, and everything looked good. With the ski idling, voltage was 12.8v. Revving the engine to 5K resulted in NO change, still 12.8v. Same result when I installed the 2nd new rectifier.
I checked the Stator leads per the manual. (Caveat: instead of using the special Sea Doo pigtail recommended by the manual, (PN 295000136) that's hard to find and expensive), by tracing the wires of the plugged in Stator to the bullet connectors in the forward electrical box, and used those. All yellow lead-yellow lead resistances were 0.9 OHMS (specs in manual are 0.1-1.0). All stator wires resistance to ground were open (other than the grounds), so the stator is within specs.
So I have 2 new rectifiers, neither are charging the battery at all, and both get really hot when the engine is running. I don't see how they can be connected wrong. All the fuses and connections are good. Am I just unlucky and got 2 bad ones? I ordered another one from SBT that looks different and is more expensive, hoping for a different result.... thanks in advance.
