Pro_Marinero
Hi all. Haven't been on here long and only got started recently with SeaDoo boats. I helped my dad put together a '95 Explorer last year and then stumbled on a $1500 '95 Speedster that I snapped up. It ran but I winterized it with a plan to take it out this year.
I did a few minor things to it (new carrier bearing, etc.) and did a trailer test at the local launch tonight. Everything worked ok except... water was coming into the engine bay. I tracked it down to a hole under the port side through-hull fitting for the shaft. Here's a picture:
Where could something like that have come from? Is it normal? My first thought that it might be a bilge drain but with a bad valve on the other end. I thought before I start shoving Splashzone in the hole I should ask the experts on here to make sure I wasn't plugging up something with a purpose.
If it's not normal, is there a reason something like this might occur? Thanks for any help you all can provide. :cheers:
