Scott Buckley
So I pulled a bonehead move and I guess didnt fully tighten my starboard drain plug fully and got 10 inches in the seadoo overnight.
Pulled the plugs rolled it over a bunch got as much water out as I could asap and it came close to firing up but a weak battery hampered that effort.
Charged up the battery but then had another issue pop up and the starter spins now but it won't engage the flywheel.
Question for everyone what else should I do with the engine until I get a new starter in there as I don't want any corrosion to get going but it was only freshwater that got in.
Second, is it possible the starter is ok since it spins just needs a bit of lube on the splines where the gear slides to engage the flywheel or is it in need of a complete unit? It may be the original starter I'm not sure.
Lastly where is a good source to buy a high quality new starter and a new battery as the seadoo is in great shape with a new premium rebuilt 787 engine and mint cosmetically too!
I'd really appreciate your help as I am pretty sure the sooner we can get it running and fully warmed up the sooner the rest of the water will be outta the engine!
Trust me I'll never make that drain plug mistake EVER again!!!
