rsatina2002
Hi another question for you to help... I just acquired my boat last july, rebuild the ECU, new fuel pump, new temp sensor port side, new plugs, new oil, treated with 1 gallon of sea foam on fuel of 25 gallons... starts easily hot or cold.... idle is always at 1,500-1,750 rpm even before treatment with sea foam.. just notice a smoke with strong gas smell at 2,500 -3,000 rpm..... my 40 gallons of fuel only runs about 7 hours... with mostly at 2,500-3,000 rpm at harbor area... any ideas if i have a stator problem of fuel pump because of a strong smell from the exhaust... normal fuel pump psi at 34, cylinder head psi is normal... please give me an input and its highly appreciated...
