TLH101
Suggestions for tuning this thing: '97 GTX 787.
Has a very slow climb in RPMs, runs up to 5200rpm and no more. If I release the throttle and hammer it quick, or hit a small wake to unload the pump, jumps right up to max RPM. If I let it drop below 5K, have to trigger it quick to rpm back.
Carbs were rebuilt with Back to OEM w/ OSD kits. Pop-off set at 30psi (lowered from 40 to get a transition). Carb low speeds set at 1 turn out, and tried every position to 2 turns at 1/8 turn increments. Hi set at 0 on Mag, 1/2 on PTO. opened both highs an additional 1/4 turn
Changed rectifier.
Tried RAVEs set at top and bottom.
New spark plugs, gapped correctly.
Bypassed fuel valve.
Tried 2 different sets of carbs.
Checked to make sure correct impeller.
Compression 145 both cylinders.
Pressure tested engine.
What am I missing?????
Changed rectifier.
