Jris88
Hey guys,
I posted week or so back about buying my first ski - long story but I pretty much inherited a '93 XP with a trailer purchase I made. Ski looks mint, owner said it ran all season just needed a starter.
Here's the steps I took:
1) Charged up the battery and gave it a shot - much to my disbelief the starter worked - engine cranked but would die the second I let go of the start button. As it was cranking a ton of water came out the back of the ski. It was getting dark and I figured I needed fresh gas and to clean carbs so I left it for the night.
2) I tried a day or so later and nothing. Starter would give one knock/thud sound but engine wouldn't crank. The PTO cover was off and you could see it turn slightly and turn back. Figuring it was the starter I swapped the starter out and no change, same thing with the new one. I tried rotating the PTO by hand with the plugs pulled and it wouldn't budge.
3) Thinking either the engine or jet pump were seized, I pulled the starter back out and then the jet pump - it was not fun. Pump spun freely once removed so that got me thinking it's the engine. I sprayed some fogging spray in the spark plug holes and let it sit overnight.
4) Yesterday, I tried turning over by hand again. Still nothing. I did some reading and figured I'd try some Marvel Mystery Oil. I poured about 3oz into each cylinder, waited about 2 hours - it seemed a looser but still very tight by hand. I took a strap wrench, wrapped around the PTO and spun. I got it moving, still with a bunch of resistance. there seems to be one spot in the 360 cycle that has more resistance. I can now spin it by hand (with some strength) until it hits that point.
At this point I'm not sure if I should try more MMO or ATF fluid? How much is too much to pour down - was 3oz enough?
Alternatively I was thinkning about pulling the block drain plugs (manual says 657 has them) and verifying no water in crank case, and then maybe pulling heads?
Any thoughts or suggestions? I'm fine with tackling a rebuild but it would be my first!
