scrump
Hey Everyone,
I was out this weekend getting my wakeboarding on when my friend ran over the rope turning to pick me up after I wiped out. I had to cut the rope because it had tightened up around the drive shaft and locked up the steering in the back. (I'm sure it is hard to get a visual, but it was a mess!!) :ack: I had to run the boat back on one engine, put it up on the trailer to take a look......and there was a about 10-15ft of rope entangled on the shaft and luckily nothing went through the impellar :hurray: I did notice though after I had cut all the rope out that the blue sleeve surrounding the shaft that comes directly out of the hull was cracked. I put the boat back on the water and everything ran fine as usual, I checked the engine comapartment several times and found no sign of any damage, no wierd noises, no excessive water take on, nothing. So my question is.....................How vital is it that I replace this sleeve and what might be some consequences that may arise from not replacing this.
As always....Thanks in Advance for any Advise,
Scrump
Scrump
