Ski and x-module for RXT 230 -19
yabbah
Hi, as I understand I should get extended vts with this? They mean more steps between min and max? I dont get it really.
This Sea-Doo exclusive accessory lets you exaggerate how high you can raise the nose or how deep you can bury it in the water.
The extended range VTS doubles the range of adjustment compared to our current standard VTS.
Adjustments are instantaneous thanks to the quick activation switch mounted on the handlebar to allow fine tuning of the watercraft trim angle while riding.
Simple plug-in connection, and includes switch, cap and hardware necessary for installation.
Standard on Sea-Doo SPARK TRIXX.
So no, it doubles the range, not the increments between max and min.
You mean I on a RXT 230 -19 I can higher it higher up, and lower it lower down then without the x-module?
Nada, I am only referencing the extended range VTS system option.
The x-module has nothing to do with VTS.
Compatibility
Sea-Doo SPARK with iBR (2017 and up - full extended range), (2016 and prior - stock range)
Not an option for your ski
Well I can see now how your confused, the extended range VTS for the Spark doubles the range and is only available for the late model Sparks.
The module package you referenced above completes the VTS range for your ski. Increases range by 50%.
So yes you will have longer (greater) range VTS for your ski.
Its amazing what a company will do to increase its profit margin at the expense of its costumers.
“Completes VTS range” admitting that they didn’t have time at the factory to give you your full range VTS
