I installed a new wear ring in the drive last night. I measured the opening against a stock seadoo prop I have in the shop. The skat trak has a much smaller opening for the seal, so the dealer was correct. Weird though, As I can't figure out where to buy one. I guess I'll call skat trak later today. I found its part number SS07, but only seems to be included with new props, & not seperatly. but I am sure it must be somewhere.
Thanks for all the help. Now I am trying to decide if I should replace the driveshaft. The shaft had wore against a rock that became logged into the intake channel. The shaft was not pefectly straight at the time, so it wore some material off the shaft but more so on one side of it. I straightened the shaft within .005" but it now has an unnatural wobble where the rock had wore off that material on one side of the shaft. Thinking it might cause a vibration..... Well, that & it just bothers me......Hhhhmmmmm.
