jwinco
So I bought a 1997 seadoo twin 717 speedster from a guy who had it in a storage unit for 8 years. The body and seats looked to be in good shape, trailer rubber was good, engine compartment was clean and he claimed it was running when he stored it. Not having space to really get into it at the storage unit, and with a bunch of other people interested, I took a gamble and bought it knowing it would need some work. So here is what I found and what I need help on.
Disclaimer - I only know enough about engines to be dangerous. Rebuilt a carb on a motorcycle once but never messed with cylinders or anything like that before. Also my compression tester is pretty old...
Here is what I've done and found...
-Put in a new battery.
-New plugs
-Drained the little bit of remaining fuel and refilled with 15 gal of premium and 2 cans of seafoam. This is the higher cleaning strength concentration and I figured more fuel would dilute whatever might be left in the tank.
-Checked fuel filters and cleaned them. Ensured o-rings were good
-Checked fuel lines - all are pliable and in good shape
-Topped off the mix-oil tank - local seadoo dealer said it probably wouldnt need to be drained and would still be good. It was about 1/4 full.
-Starboard engine spark arrestor was clean, compression was 140 on each cylinder.
-Port engine was trouble... Bracket holding spark arrestor was broken, airbox was flopping. Removed the air box from the carb and the neck of the intake was cracked/broken off where one of the bolts attaches. The other side the bolt was stripped and the threaded hole was all worn out. I'm thinking the guy kept running it without knowing the damage and the vibration opened the hole up. Pics attached.
-Port Engine compression in front cyl was 145, but rear cyl was about 120.
-Missing the infamous rope box lid
Starting with the starboard engine, I sprayed some hand-mixed fuel/oil/seafoam into the carb to get it to catch. With hose attached it will run for a bit but dies at idle. Lots of carbon flew out of the exhaust. Did the cmpression test on this engine AFTER running it a bit but then let it cool. Going to repeat the process over the next couple days to move the seafoam/fuel through the system and hopefully clean it out a bit. Both cyl 140. I did run the compression test on the starboard side after starting the engine but then letting it cool.
Havent tried starting the port engine. I've ordered a used carb and the arrestor mounting bracket to install first. Compression test on this side was without running it at all. 145 front cyl and 120 rear cyl
So questions -
1. Am I missing anything major for trying to get this going?
2. My port engine compression difference - could that be related to testing it after sitting for 8 years? Could that change after I get it running and test again? If not, how bad is it to have the difference in those 2 cylinders?
3. Tips for getting the starboard engine to run and stay running? Wont start without a squirt of gas currently and dies at idle. Once it's running I can rev it and it keeps going, so it's getting fuel.
4. Can I run it on 1 engine to putt around a little bit while I wait on fixing the port side?
5. There is a little aluminum limiter on the starboard jet but not the port jet. The roll pin on the starboard side was coming out and the thing was dangling, making me think I maybe lost the port side. Anyone know what it does and if there are supposed to be one on each side? See Pics
Any tips and advice would be helpful. Also any leads on a rope box lid.
-New plugs
So questions -
