Siri 98 F -16 XR 175
Techk
Runs good 6000 RPMs for first 20 minutes then you go again and want to go to 4500 RPMs doesn’t seem to Miss ,I read something about there being slow speed and high speed pickups under the flyaway can anybody help me out with this thanks
There is a high and low speed ignition system. The system electronicly shifts between. There is on one trigger base (coil) under the flywheel. It consists of the base and 3 molded-in coils. Pretty easy to check. 6 pin connector, on bracket aft of flywheel. Follow the book. But first- visual check the insulation on the wires. Is it crumbly or smooth? The old original triggers had crappy insulation.
