I have a 2004 Sportster 4Tec. Has anyone installed a siphon bailer setup like there is in some skis in this or similar model? Are you glad you did it? Any comments on this topic, positive or negative are appreciated. Thanks
Yes, people have. I saw other people had done it while I was considering it. Honestly, I thought the 2004-2006 Sportsters had it before Sea-Doo discontinued that feature.
Yea. I drilled it from the outside with the smaller bit that matches the plastic part, then drilled from the inside to mount the NPT hose barb fittings. No epoxy needed.
