should the flush houses be plugged while running in water? -95 speedster
maaah
As title, should i plug the flush houses at the top at the engine compartment while running in water?
The boat is a 1995 speedster with 657x engines.
If it's the flush connector in the fiberglass body, just under the deck lid... Then yes, they are supposed to be capped off. Otherwise, you will have water in the storage compartment.
