uraceulose
I finally got one of the engines fired up on this thing, the other engine has two broken exhaust studs that I found.
My issue is that even after letting it run for a minute on the hose it wants to die when I rev the throttle up to about 1/3 throttle.
It’ll idle fine but once I open the throttle it wants to die unless I bring it right back to idle. Any ideas what I need to adjust or is this normal? I pulled all 4 carbs and rebuilt to the best of my ability. A couple of the fuel block screws I was unable to loosen even with an impact screw driver so I had to leave alone. The engines ran great before I pulled the carbs off and put them back on.
