nesnfred
I have 2008 Wake 230. My shift cable broke. I ordered one from Amazon and it matched up perfectly…I thought. The shift mechanism at its base has four half circle slots on the bottom, each corner. The shift cable is held in place by a metal plate that locks cable in place in the back left half circle slot.
Once I got it all installed, I realized the neck of the cable (specifically the crimp sleeve as it transitions to the connecting shaft) on the shift mechanism side is more narrow than the original one. It keeps slipping through that slot which is problematic because the cable must be secured so the inner wire connected to the reverse bucket has to move independently of the outer cable sleeve.
Interestingly, the two front half circle slots on the bottom of the shift mechanism are more narrow and the new shift cable locks perfectly in the front left one. The only problem is that now the gear selector is in forward when pulled back and reverse when pushed forward. I’ll have to adapt!
Anyone else run into this? Are all the new cables like this?
