So I had oil spitting out of both RAVE valves on one of my engines so I decided to go under the knife and check the Bellows/clean the Valve. When I went to go re-install I noticed the top of one of the bellows was different. I removed the caps from the other engine and they both looked like the one on the right. Although, the one on the right did not have a 10mm bolt on top of it and it also looked melted.
So to recap- The one on the left is the only one that looks like that, however the one on the right did not have a 10mm bolt on top. Both rave valves on the other engine are in perfect condition and look like the one on the right in the picture below.
Where do I go from here?
