separating a drive shaft
Dutch
How do I separate the drive shaft on a 1998 GTS? Im trying to take the engine out to replace the tension spring for the oil pump mech. Dutch
that shaft can be a pain to pull. the stainless ring on the shaft has to go back about a half inch to expose a retaining ring that holds it in place. i just take the pump out so the shaft is loose, then pull motor forward off the shaft. how did the carb go?
