Send Doo Challenger 180 2005
dlemek
This boat has an issue with the oil light and alarm sounding.
I have replaced the oil pressure sensor and still have a problem.
One mechanic stated that the engine may be over heating, the oil becoming too hot, thus going into alarm mode.
What should I check next?All suggestions greatly appreciated.
Denis
Maybe a bit more info on the problem?
When does the light/alarm come on? Is it right at start-up? Does it come on after running for a bit? When light comes on have you checked the oil level? Oil level when engine is warm and shut down for a few minutes? Have you checked your coolant level? Is it normal?
Why did your mechanic think it was overheating? Any signs?
I'd get a cheap IR Thermometer and take it out with you next time you run the boat. Take temps of the exhaust manifold, hoses and muffler. Take temps of block where temp sensor is located as well. Operating temp of our 2012 is 183 C.
I lived with this problem!!!!
Not an easy one
First Did you get supercharger work done? Then the sensors 2 are dirty, need change.
Voltage from the charging must be up to spec or the computer emit funny messages
That is a sea doo !!!
