Selector knob
Does anyone know about this selector knob under steering column, marking worn, it has 3 positions, and where does it need to be during running
2000 gs 718
Gas Pump symbol is on and for normal operation.
No gas pump icon is off and should be in this position when not in use.
RES is reserve so when you run out of fuel RES gives you about a gallon to get back to shore.
So it's a gas shut off valve knob, what is RFS
Did you not read my comment above?
It is not RFS, that is a KTM thing Racing Four Stroke.
So,the attached pic shows it in the off position, correct
