BoyzFunBoat
My 2005 Sea Doo Sportster Le DI has about 175 hours. It's ROTAX 947, 2-stroke direct injection engine.
I'm the 3rd owner, it had 149 hours when I purchased it last year. I've always used Sea-Doo brand XP-S 2 Stroke Synthetic Oil. When I purchased it, I had a new impellor and wear ring installed and the top speed was 49 MPH (around 7,500 RPM). I was real happy about that! I should note that I ran this boat hard, often 95%-100% throttle for 10-15 minutes at a time, while pulling two kids on a tube. Gradually, week by week, the top RPM decreased and the top speed decreased to about 33 MPH. Also, towards the end of the season, it started cutting off when it was running at higher RPMs (while engine was hot), but on some outings, it wouldn't cut off at all. If I let it cool down for 3-5 minutes it would start right back up and usually run for 5-20 minutes. This cut-off, cool down, restart cycle was becoming more and more frequent, all the while the top speed and top RPM was decreasing. Eventually, it got to the point where after a cut off, the boat required much longer (5-15 minutes) to cool off in order to start.
I took it to a mechanic and the compression on one cylinder was only about 25 PSI. The other was about 135 PSI. He said I needed a new motor or at least a top end rebuild, so I went with the cheaper top end rebuild.
The first time in the water, I took it easy, gradually throttling up and down through the RPM range of 2,000 to 5,000 for the first 30 minutes. I got up on a plane a half dozen times and everything was running smoothly. The first attempt at a brief speed run, the motor cut-off at around 7,000 RPM. After letting everything cool for 2-3 minutes, I started up and did another 10-15 minutes of break-in. The second attempt at a speed run, the motor cut off again at 7,200 RPM. Again, I let the motor cool and returned to the landing keeping RPM below 5,000.
I immediately took the boat back to my mechanic (the very next day I picked it up) and he said first test would be a compression test. I had already lost compression on one cylinder, down to only 135 PSI. The other cylinder is still at 150 PSI. Mechanic says something is causing a cylinder to overheat and it's seizing, which is causing the motor to cut off. He removed the RAVE valve and did a visual inspection piston with the 135 PSI cylinder and said there were noticeable marks on the piston indicating a partial seizure.
He thinks it could be a leaking crankshaft gasket, but won't know until he spends a lot of labor hours to take the motor apart and inspect the crankshaft. He also said it could be something else, he just wasn't sure. His computer didn't show any errors and I never heard any alarms during the break-in. If I put in a rebuilt motor, and it fails under warranty, I'll still have to pay labor and freight, so I'm not doing that until I can determine the root cause of the issue.
I'm going to get a second opinion. Anyone have any suggestions on what's going on?
