Seized Engine - 97 Challenger 1800
TheCabralFamily
Question: Can a rave valve that has come loose cause an engine to seize? I had the rave valves replaced, and first 2 hours on the water one vibrated loose (about 3/8"). I tightened it back up, ran for another 20 mins then the engine shut down.and seized.....now I'm looking at an $1,800 rebuild....and want to make sure I know what caused it.
Coincidence? Same valve same engine?
I thought I had seized a motor - turned out to be the jet unit - loose rave valves shouldn't be an issue. Good luck.
