I have a new to me 2008 SeaDoo 230, on a new aluminum Karavan trailer(stock trailer for SeaDoo 230). Though this is a much bigger boat than I'm used to, I'm not new to trailering small boats and jetski's.
The problem;
I tried to lower the boat in the water till the water was on top of the wheel fenders and found it was not far enough down to launch, meaning the boat was not floating yet (shallow launches here in FL) and pumps were not in enough to assist. I lowered the trailer further in the water till the water was at the front bow support post and the boat was just lifting off the bunks and could be pushed off at that time with some effort but the bow keel does not have enough support and it rolled hard over the front bow roller causing a gouge in the rub rail or gunnel wrap and dropped approx 3-4 inches. Again this is a stock trailer for this boat and has a stock set up.
The next issue;
When I tried to recover the boat, I first tried the water level at the top of the wheel fenders and was able to drive the boat on approx 3/4 of the way and lost pump pressure and forward momentum. I then latched the bow eye and felt the extreme pull with the winch and stopped immediately. I got in my truck and tried backing down several times in 1 foot increments and though this got the boat up to the front bow support, it was 3-4 inches below the bow support roller. By this time I had so much traffic backed up, I drove the boat out of the water, this of course flattened the boat and I had a few inches to move the boat forward that could not be done with the winch, so I did something I've done before but really prefer not too, to the extreme. In a straight line I rolled the truck forward under 5mph and hit the brakes hard, this seated the boat properly on the trailer. Boat is fine, but until I figure out how to make this trailer workable for this boat, I will not be going out.
Anyone with this stock set up out there that has solved this issue? and How? or Anyone with a similar sized boat that has solved this? Or no trouble at all with the stock set up? Tips and Tricks? am I missing something? Does the trailer need extra equipment to support the bow/keel for launch and recovery? I can't lower the bunks anymore than they are, ???
Or is this something for professionals? If so, what should I look for?
Any help would be very much appreciated, my family and I love the boat, but launch and recovery has to be better controlled.
The problem;
The next issue;
