Ive got a slow leak that will put a few gallons per hour into my hull, nothing the bilgepump cant handle if its working well. But its time to search out and fix this..any suggestions?
Ive watched the hoses coming off the exhaust while moving slow (6mph) and nothing is spraying, and while stationary bending into engine bay and revving both engines...nothing.
The water in the Bildge is HOT!!! but I believe it is because its surrounding the hot engines and Exhuast..but it may be hot cause its coming from a manifold? any easy way to check that out of water?
Ive read there is a seal on the Grate Pushrod that leaks?
Ive heard the hull mate to topshell will leak while under way as well near the back?
My first plan tonight is to run the garden hose into the hull while its on the trailer and fill it up a good ways and see if I can spot it leaking out (Reverse Physiology! or Leak -Ology)
Thx Renomaan
Anyone have any thoguhts?
Thx Renomaan
