eavega
Hey all
I'm finally getting ready to re-assemble my 1997 GTX after a top-end rebuild. I'm going through the shop manual and verifying all the sealants and other assorted fluids I'm going to need to do a proper re-assembly. I've already come across several suggestions of not using some of the sealants indicated in the manual; specifically I have been directed to use three bond 1211 sealant on the cylinders instead of the Loctite 515 (which I later learned was superseded by Loctite 518) which the manual indicates. I wanted to know if there were any additional suggestions for the following (both of these are used in reassembling the exhaust):
736 Heat Resistant Sealant
732 Clear Multi-purpose sealant
I searched on the web and apparently you can order over amazon, but I doubt I need a 300 ml tube for the small applications, and was hoping to find something equivalent that I could purchase in a more reasonable quantity.
Any help you all can provide would be greatly appreciated.
-Eric
-Eric
