Just took my 95 gtx out of the lake after using it for the week on holidays and it was full of water right up to the engine mounting plate. THe drive shaft was just under water.
Before I drained it I saw it was dripping slowly where the drive shaft enters the hull.
I drained it and saw the Seal Carrier had come out of the rubber hose that it should be clamped inside. So I am assuming that is why it was leaking. The hose clamp that holds it in was totally loose and spins on the black hose. I recently had my dealer put a new boot on my drive shaft so I am guessing they didn't tighten this clamp and that is why the Seal Carrier popped out. The Seal carrier spins freely on the drive shaft so I don't think the bearings are seized. the dealer should have greased it all as well.
My question is do I slip it back in, tighten the hose clamp, grease the fitting and go for a ride, or has the fact it ran with the seal carrier loose destroyed the seal and messed up the bearings?
I would like to go on the water tomorrow and I am not confident in removing the pump myself so I could inspect it more carefully.
Do I take a chance or do I just go to the dealer and miss my ride
