Good day guys,
Hope all is well with you all. The weekend I discovered a leak on my drive shaft of my Seadoo XPL 98 model. I read a lot of threads which all basically come down to the carbon ring. I pulled the pump out and removed the drive shaft, I did not see any cir-clips or O rings on the shaft or close to the ring. Can this be the problem to the leak or would it be the carbon seal itself?
The seal has very minor scratches on the inside, you can barely feel them with your finger and you have to look in reflective light to see them.
Before I order the new parts I would just like to find out if the O-rings and circlips can be the cause of the lek or should I just go ahead and replace the ring.
Thank you guys in advance!
Best regards,
Jacques
Best regards,
Jacques
