Seadoo xp 1997 no beep , will not start
Pit'n
Hi , i buy a seadoo xp 1997 cheep because of start problem , the problem is , no beep when put lanyard in post , but it beeps if i press star button 5 times , and vts works , and vts gauge too , fuel gauge are not working , tell from previus owner , if i ground the black cabel on post , it beeps 2 times when i put on the lanyard and i turn over , but wont start , anyone had similar problem ?? Thank you for any help . (Sorry for bad english i am from norway )
Best regards Ronny , Norway
Hi and welcome to the Seadoo forum.
The small black wire from the rear Ebox needs to be attached to the neg. battery terminal, try permanently attaching the wire and post back.
Lou
Is The rear e box The one whit coil and stater solenoid in ? Cant find any Else . Only one in The rear hatc where The vts motor sits inn .
Correction : it is The black and yellow cabel from dess post i ground , to Get The system working , not The black one .
Lou
The 97 XP doesnt have that little ground like all the other X4's do
